Zenith 809 lacquer color scheme?
It is chrome. I cleaned it up with naval jelly. I took it to a plating company, and they're going to re plate it for me. The cabinet is looking good. It will look stunning.
Zenith 809 lacquer color scheme? - by Sourbone - 02-24-2021, 04:09 PM
RE: Zenith 809 lacquer color scheme? - by Arran - 02-26-2021, 06:36 PM
RE: Zenith 809 lacquer color scheme? - by Sourbone - 02-27-2021, 11:54 PM
RE: Zenith 809 lacquer color scheme? - by Arran - 02-28-2021, 04:05 AM
Philco 91 Tuning Condenser
There are currently 10535 online users. [Complete List]
» 2 Member(s) | 10533 Guest(s)
