GE model GD-60
Nice looking set!!! If your ballast tube is open it can be replaced with a diode on this set.
Good luck!
GE model GD-60 - by Jayce - 08-03-2010, 02:34 PM
Re: GE model GD-60 - by philcoradio1234 - 11-07-2010, 08:16 PM
Re: GE model GD-60 - by Art Hoch - 03-28-2011, 04:46 PM
Re: GE model GD-60 - by Jayce - 03-28-2011, 04:49 PM
Re: GE model GD-60 - by 7estatdef - 03-28-2011, 08:22 PM
Eico 232 VTVM Schematic
There are currently 8450 online users. [Complete List]
» 2 Member(s) | 8448 Guest(s)
