chassis feet
Does anyone know where I can find the rubber chassis feet for 1941-42 Philco console radios? I've look in radio Daze and Antique radio supply with no luck. MIne are crumbling and splitting.
Thanks
chassis feet - by Tom Ferguson - 02-28-2021, 08:05 PM
RE: chassis feet - by Paul Philco322 - 02-28-2021, 08:23 PM
RE: chassis feet - by unclevinny86 - 03-03-2021, 11:02 PM
There are currently 9113 online users. [Complete List]
» 2 Member(s) | 9111 Guest(s)
