Philco 84-B Early Model
Should be a good resto candidate. Simple circuitry and fairly easy to find parts incl power transformer. Cabinet looks solid.
Philco 84-B Early Model - by philconerd - 03-28-2011, 12:00 PM
RE: Philco 84-B Early Model - by philconerd - 04-05-2013, 02:21 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-05-2013, 03:42 PM
RE: Philco 84-B Early Model - by Jayce - 04-05-2013, 05:35 PM
RE: Philco 84-B Early Model - by philconerd - 04-05-2013, 06:53 PM
RE: Philco 84-B Early Model - by Ron Ramirez - 04-05-2013, 08:12 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-05-2013, 10:59 PM
RE: Philco 84-B Early Model - by Jayce - 04-06-2013, 04:39 PM
RE: Philco 84-B Early Model - by philconerd - 04-07-2013, 07:10 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-08-2013, 08:45 PM
RE: Philco 84-B Early Model - by philconerd - 04-10-2013, 03:30 PM
RE: Philco 84-B Early Model - by philconerd - 04-11-2013, 01:30 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-12-2013, 05:54 PM
Re: Philco 34-B Early Model - by 7estatdef - 03-28-2011, 03:01 PM
Re: Philco 84-B Early Model - by philconerd - 03-28-2011, 05:41 PM
Re: Philco 84-B Early Model - by 7estatdef - 03-28-2011, 06:27 PM
Re: Philco 84-B Early Model - by TA Forbes - 03-28-2011, 09:35 PM
Re: Philco 84-B Early Model - by philconerd - 03-29-2011, 01:10 PM
Re: Philco 84-B Early Model - by 7estatdef - 03-29-2011, 06:11 PM
Re: Philco 84-B Early Model - by Jim Berg - 04-13-2011, 11:40 PM
Re: Philco 84-B Early Model - by retroradios - 04-17-2011, 07:07 PM
Re: Philco 84-B Early Model - by 7estatdef - 04-18-2011, 09:00 PM
Philco 91 Tuning Condenser
