Philco 582
I've checked all the usual places Betmans, Riders, radio museum and radio attic.
Waiting to see what Ron has in the way of documentation. He said he has some
data. I'm just about out of options but I'll keep searching. I just found this at a
ham fest in Dalton Ga this past weekend. The chassis is horribly rusted. Going
to take a lot of work to clean up. Anyway thanks for your suggestion.
Cheers
Danny
Philco 582 - by Danny - 03-01-2021, 04:11 PM
RE: Philco 582 - by OldRestorer - 03-01-2021, 06:26 PM
RE: Philco 582 - by John Bartley - 03-01-2021, 07:45 PM
RE: Philco 582 - by klondike98 - 03-01-2021, 09:32 PM
RE: Philco 582 - by Arran - 03-01-2021, 09:37 PM
RE: Philco 582 - by OldRestorer - 03-01-2021, 10:21 PM
RE: Philco 582 - by Ron Ramirez - 03-02-2021, 12:33 AM
RE: Philco 582 - by Danny - 03-02-2021, 01:43 PM
RE: Philco 582 - by Ron Ramirez - 03-02-2021, 02:04 PM
RE: Philco 582 - by Simon Wa3uay - 03-11-2021, 08:25 PM
RE: Philco 582 - by morzh - 03-12-2021, 12:45 PM
RE: Philco 582 - by Ron Ramirez - 03-12-2021, 01:05 PM
RE: Philco 582 - by David - 03-12-2021, 01:24 PM
Philco 91 Tuning Condenser
