Magnavox Model FM-43 found
Yes, it is a very nice looking set and it was very easy to recap (it only had 3 caps that needed replacing), and I actually had a relative that worked at Magnavox from the 1940s-1960s.
Fort Wayne is about 90 minutes Southeast of me, I have family down there.
Anyone have the Sams Photofact 670-6?
Magnavox Model FM-43 found - by captainclock1988 - 03-03-2021, 04:46 PM
RE: Magnavox Model FM-43 found - by captainclock1988 - 03-03-2021, 10:20 PM
There are currently 10884 online users. [Complete List]
» 2 Member(s) | 10882 Guest(s)
