Volume won't go completely down
Sound out of a radiio iis always a good sign. Perhaps he On/off switch is shorted. I wish they were all that easy.
Volume won't go completely down - by Robin - 03-29-2011, 10:27 AM
Re: Volume won't go completely down - by codefox1 - 03-29-2011, 11:21 AM
There are currently 8630 online users. [Complete List]
» 2 Member(s) | 8628 Guest(s)
