46-350 code 125
https://philcoradio.com/library/download...6-1947.pdf
Read the service notes @ the bottom of the code 125.
46-350 code 125 - by Rick Clark - 03-07-2021, 01:45 PM
RE: 46-350 code 125 - by Radioroslyn - 03-07-2021, 02:20 PM
RE: 46-350 code 125 - by RodB - 03-07-2021, 02:36 PM
RE: 46-350 code 125 - by Rick Clark - 03-10-2021, 04:15 PM
Philco 91 Tuning Condenser
