Philco 84-B Early Model
Oh it's not too scary! On lot of the early Philcos the primary of the of the anttena coil and the feedback winding of the oscillator coil go open. The small cotton covered wire rots and you will see green spot in the winding. You can check it with an ohm meter all should measure a very low resistance like a few ohms. If not it's time to rewind!
Philco 84-B Early Model - by philconerd - 03-28-2011, 12:00 PM
RE: Philco 84-B Early Model - by philconerd - 04-05-2013, 02:21 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-05-2013, 03:42 PM
RE: Philco 84-B Early Model - by Jayce - 04-05-2013, 05:35 PM
RE: Philco 84-B Early Model - by philconerd - 04-05-2013, 06:53 PM
RE: Philco 84-B Early Model - by Ron Ramirez - 04-05-2013, 08:12 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-05-2013, 10:59 PM
RE: Philco 84-B Early Model - by Jayce - 04-06-2013, 04:39 PM
RE: Philco 84-B Early Model - by philconerd - 04-07-2013, 07:10 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-08-2013, 08:45 PM
RE: Philco 84-B Early Model - by philconerd - 04-10-2013, 03:30 PM
RE: Philco 84-B Early Model - by philconerd - 04-11-2013, 01:30 PM
RE: Philco 84-B Early Model - by 7estatdef - 04-12-2013, 05:54 PM
Re: Philco 34-B Early Model - by 7estatdef - 03-28-2011, 03:01 PM
Re: Philco 84-B Early Model - by philconerd - 03-28-2011, 05:41 PM
Re: Philco 84-B Early Model - by 7estatdef - 03-28-2011, 06:27 PM
Re: Philco 84-B Early Model - by TA Forbes - 03-28-2011, 09:35 PM
Re: Philco 84-B Early Model - by philconerd - 03-29-2011, 01:10 PM
Re: Philco 84-B Early Model - by 7estatdef - 03-29-2011, 06:11 PM
Re: Philco 84-B Early Model - by Jim Berg - 04-13-2011, 11:40 PM
Re: Philco 84-B Early Model - by retroradios - 04-17-2011, 07:07 PM
Re: Philco 84-B Early Model - by 7estatdef - 04-18-2011, 09:00 PM
Philco 91 Tuning Condenser
