Please, drawings of console cases ...
Threads: 11
City: Greenlawn
State, Province, Country: NY
Hi RadioSvit,
Wonderful work. Your skills in building the cabinets that you reproduced is outstanding!!
I find it much easier to fix a radio electronically than to build a cabinet. I also fix cars and find it easier to rebuild engines and transmissions than to repair a rusted or dented auto body. I wish I had auto body skills, as I have a 1964 Lincoln Continental 4 door convertible that needs a total body restoration. This will be my retirement project.
RE: Please, drawings of console cases ... - by MrFixr55 - 03-17-2021, 10:11 PM
Hi Mike, I believe I tried different ways to change the header for my post but no luck. Anyway thanks for changing it fo...462ron — 04:02 PM |
Since these radios operated in harsh environments (temp changes and vibration) you could touch a soldering iron to all t...GarySP — 03:18 PM |
Thank you Gary. Hi Morzh. These radios are 6 transistor radios. Sadly no tubes. Thanks though.R3Sons — 02:19 PM |
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM |
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM |
Welcome to the Phorum, R3Sons! I have very limited experience with car radios other than installing custom radios back ...GarySP — 01:08 PM |
OK, I need to rename this thread to say..Eico 368 TV/FM Sweep Generator instead of the current title..Heathkit Sweep Gen...462ron — 12:49 PM |
Hello, I have a Philco (Ford) 6TPZ and a 5TPO radio. I replaced the electrolytic capacitors in both. I have the SAMS m...R3Sons — 12:29 PM |
Hello Peter,
Thank you for posting that !!
Eico 232 VTVM Schematic
There are currently 10164 online users. [Complete List] » 1 Member(s) | 10163 Guest(s)
