53-956 Philco
Looking for a little help on this radio.  i am somewhat of a beginner on understanding schematics.  For this radio the Base View Part Placement
diagram shows no connection on 38A & 38B, but the Philco schematic shows different.  The way I see the schematic is:
38A go to Pin 2 of the Output tube
38B go to Pin 1 of the 1st Audio tube
38C go to Pin 7 of the Output tube
38D go to Pin 1 of the Output tube
C26 go to Pin 7 of the Output tube
I got all my info from Nucow Schematics Vol 23, pages 661-666
Any and all help would be much appreciated.
Once again Thanks,
Rick Clark
53-956 Philco - by Rick Clark - 03-27-2021, 11:31 AM
RE: 53-956 Philco - by David - 03-27-2021, 12:36 PM
RE: 53-956 Philco - by David - 03-27-2021, 12:41 PM
RE: 53-956 Philco - by Radioroslyn - 03-27-2021, 07:08 PM
RE: 53-956 Philco - by Rick Clark - 03-27-2021, 07:29 PM
RE: 53-956 Philco - by David - 03-27-2021, 09:20 PM
RE: 53-956 Philco - by mikethedruid - 03-27-2021, 10:17 PM
Philco 91 Tuning Condenser
There are currently 9152 online users. [Complete List]
» 2 Member(s) | 9150 Guest(s)
