Zenith 12a58 cabinet makeover.
3 days into this zenith and I'm finished. New preproduction grill now available has been  installed, inside cabinet detailed and painted factory zenith blue. Custom color and toning done with grain filled veneered areas. Sealed and re sanded, 6 coats of mohawk semi gloss precat Lacquerer. No rubbing out. Outstanding example of a zenith console professionally refinished cabinet. Thanks for looking Fred Taylor Dallas tx
Zenith 12a58 cabinet makeover. - by Fred Taylor - 03-28-2021, 12:39 AM
RE: Zenith 12a58 cabinet makeover. - by 462ron - 03-28-2021, 04:31 PM
RE: Zenith 12a58 cabinet makeover. - by 462ron - 04-04-2021, 09:59 AM
There are currently 10216 online users. [Complete List]
» 2 Member(s) | 10214 Guest(s)
