Atwater Kent 82Q
If the cabinet is in good shape go for it, especially if it's cheap. I think the 82 is one of the nicest cathedral designs ever made. You've got a basement full of AC sets, you need at least one battery version of an old radio.
Atwater Kent 82Q - by morzh - 03-27-2021, 10:39 PM
RE: Atwater Kent 82Q - by Eliot Ness - 03-28-2021, 08:34 AM
RE: Atwater Kent 82Q - by Arran - 03-28-2021, 10:51 PM
RE: Atwater Kent 82Q - by morzh - 03-29-2021, 12:36 AM
RE: Atwater Kent 82Q - by Ron Ramirez - 03-29-2021, 08:06 AM
RE: Atwater Kent 82Q - by Arran - 03-29-2021, 10:49 PM
RE: Atwater Kent 82Q - by morzh - 03-30-2021, 12:07 AM
RE: Atwater Kent 82Q - by RadioSvit - 03-30-2021, 04:15 PM
RE: Atwater Kent 82Q - by morzh - 03-30-2021, 04:19 PM
Eico 232 VTVM Schematic
There are currently 6573 online users. [Complete List]
» 2 Member(s) | 6571 Guest(s)
