Refinishing my 40-180 cabinet
I use a medium walnut dye based lacquer on the majority of the cabinet to show the grain. I use a dark walnut pigment based lacquer on the trim parts along the bottom and top edges where the wood grains don't really show. I mask off all but the trim parts and spray the dark walnut, then finish with the medium walnut after removing the masking.
Refinishing my 40-180 cabinet - by fwmartin2000 - 04-14-2020, 11:01 PM
RE: Refinishing my 40-180 cabinet - by GarySP - 05-25-2020, 08:56 AM
RE: Refinishing my 40-180 cabinet - by klondike98 - 05-27-2020, 07:40 PM
RE: Refinishing my 40-180 cabinet - by PhilcoJohn - 06-03-2020, 07:16 PM
RE: Refinishing my 40-180 cabinet - by KCMike - 06-04-2020, 06:53 PM
RE: Refinishing my 40-180 cabinet - by tbone - 09-18-2020, 06:19 PM
RE: Refinishing my 40-180 cabinet - by fwmartin2000 - 03-29-2021, 08:31 AM
