Poll: Refinish, or not refinish? - You do not have permission to vote in this poll.
Refinish!
0%
0
0%
Leave it alone!
100.00%
2
100.00%
* You voted for this item. Show Results
1924 FADA Neutrola: Refinish, or not?
Kirk, thank you for your advice. I will try your process first. I can always get more aggressive if the finish does not respond to it. -Dionj
1924 FADA Neutrola: Refinish, or not? - by Dion - 03-29-2021, 01:53 PM
RE: 1924 FADA Neutrola: Refinish, or not? - by Dion - 03-29-2021, 04:42 PM
There are currently 8422 online users. [Complete List]
» 2 Member(s) | 8420 Guest(s)
