Need VEF Baltika help
Brenda
The second photo is grainy, but if my perception is correct, it is a low-turn coil with fairly thick wire.
Worst case, would you think you are able to rewind that thing?
PS. You are first American who call them tubes "lamps". I though that was us Russkies who do that Icon_lol
Or are you trying to get in the Russian groove with Russian radios and Russians being the consultants?
Need VEF Baltika help - by BrendaAnnD - 03-30-2021, 08:10 AM
RE: Need VEF Baltika help - by morzh - 03-30-2021, 01:38 PM
RE: Need VEF Baltika help - by morzh - 03-30-2021, 02:30 PM
RE: Need VEF Baltika help - by RadioSvit - 03-30-2021, 04:00 PM
RE: Need VEF Baltika help - by BrendaAnnD - 03-30-2021, 04:00 PM
RE: Need VEF Baltika help - by BrendaAnnD - 03-30-2021, 04:06 PM
RE: Need VEF Baltika help - by morzh - 03-30-2021, 04:13 PM
RE: Need VEF Baltika help - by RadioSvit - 03-30-2021, 04:35 PM
RE: Need VEF Baltika help - by morzh - 03-30-2021, 06:52 PM
RE: Need VEF Baltika help - by BrendaAnnD - 03-31-2021, 01:30 AM
RE: Need VEF Baltika help - by morzh - 03-31-2021, 10:34 AM
RE: Need VEF Baltika help - by RodB - 03-31-2021, 10:45 AM
RE: Need VEF Baltika help - by RadioSvit - 03-31-2021, 02:46 PM
RE: Need VEF Baltika help - by BrendaAnnD - 03-31-2021, 05:55 PM
RE: Need VEF Baltika help - by morzh - 03-31-2021, 08:22 PM
RE: Need VEF Baltika help - by BrendaAnnD - 03-31-2021, 09:43 PM
RE: Need VEF Baltika help - by morzh - 03-31-2021, 11:44 PM
RE: Need VEF Baltika help - by BrendaAnnD - 04-01-2021, 02:57 AM
RE: Need VEF Baltika help - by RodB - 04-01-2021, 08:50 AM
RE: Need VEF Baltika help - by BrendaAnnD - 04-01-2021, 10:36 AM
RE: Need VEF Baltika help - by morzh - 04-01-2021, 11:40 AM
RE: Need VEF Baltika help - by RadioSvit - 04-01-2021, 12:02 PM
RE: Need VEF Baltika help - by morzh - 04-01-2021, 12:34 PM
RE: Need VEF Baltika help - by Arran - 04-11-2021, 11:48 PM
RE: Need VEF Baltika help - by RadioSvit - 05-01-2021, 05:39 AM
RE: Need VEF Baltika help - by morzh - 05-01-2021, 09:25 AM
RE: Need VEF Baltika help - by RadioSvit - 05-01-2021, 10:39 AM
There are currently 8479 online users. [Complete List]
» 1 Member(s) | 8478 Guest(s)
