Value of 46-1201
Thanks for the info. As I have plenty of 78's and I'm intrigued with the method in which this model operates, I would consider $50 if I can find one in pretty good original shape. The online auction prices are ridiculous from what I've seen. And few of the sellers can even be certain of the operational status of their items as usual.
Value of 46-1201 - by Squid100 - 04-06-2021, 01:54 PM
RE: Value of 46-1201 - by Arran - 04-06-2021, 04:44 PM
RE: Value of 46-1201 - by Squid100 - 04-06-2021, 04:52 PM
RE: Value of 46-1201 - by Radioroslyn - 04-06-2021, 05:20 PM
RE: Value of 46-1201 - by Squid100 - 04-06-2021, 07:18 PM
RE: Value of 46-1201 - by mikethedruid - 04-06-2021, 08:20 PM
RE: Value of 46-1201 - by NostalgiaRadioTime - 04-06-2021, 09:05 PM
RE: Value of 46-1201 - by Arran - 04-06-2021, 10:07 PM
RE: Value of 46-1201 - by W8ZV - 04-12-2021, 09:22 AM
RE: Value of 46-1201 - by OldRestorer - 04-12-2021, 09:16 PM
RE: Value of 46-1201 - by Arran - 06-25-2021, 06:46 PM
There are currently 5515 online users. [Complete List]
» 2 Member(s) | 5513 Guest(s)
