RCA R-32 Speaker
New information as the saga continues, In my quest for the value of the FC coil it was suggested I send an email to the Radiola Guy and I did and heard back and he says the FC coil should be 1400 ohms. I have also figured out this is not the original speaker among other things that have been done. I think for now I will put in a PM speaker with a 1400 ohm resistor and see if I can get something out of this.
RCA R-32 Speaker - by Eric - 04-07-2021, 05:34 PM
RE: RCA R-32 Speaker - by Radioroslyn - 04-07-2021, 05:55 PM
RE: RCA R-32 Speaker - by Eric - 04-08-2021, 10:43 AM
RE: RCA R-32 Speaker - by OZ4 - 04-08-2021, 11:55 AM
RE: RCA R-32 Speaker - by OZ4 - 04-08-2021, 12:11 PM
RE: RCA R-32 Speaker - by OZ4 - 04-08-2021, 12:20 PM
RE: RCA R-32 Speaker - by OZ4 - 04-08-2021, 12:50 PM
RE: RCA R-32 Speaker - by Eric - 04-08-2021, 05:42 PM
RE: RCA R-32 Speaker - by Eric - 04-09-2021, 09:39 AM
RE: RCA R-32 Speaker - by rghines1 - 04-09-2021, 05:07 PM
RE: RCA R-32 Speaker - by OZ4 - 04-10-2021, 10:17 AM
RE: RCA R-32 Speaker - by Eric - 04-10-2021, 11:48 AM
