Was there a 36-610?
Nope, the 1936 model was just 610.
1937 was when Philco started appending the model year prefix to model numbers.
Mike Tobin at Rock Sea Enterprises can help with a very good dial replacement.
Was there a 36-610? - by n9vu - 04-02-2006, 09:56 PM
[No subject] - by Chuck Schwark - 04-02-2006, 11:00 PM
[No subject] - by n9vu - 04-03-2006, 06:23 AM
[No subject] - by Chuck Schwark - 04-03-2006, 09:10 AM
[No subject] - by n9vu - 04-03-2006, 07:58 PM
Philco 91 Tuning Condenser
There are currently 6902 online users. [Complete List]
» 2 Member(s) | 6900 Guest(s)
