Model 60 dial replace
What can I use in place of the original rivets to mount a new dial face?
2nd try: did model 60s have a factory standard location for the speaker field coil? Right, left, up, down?
Model 60 dial replace - by fenbach - 04-17-2021, 12:21 PM
RE: Model 60 dial replace - by radiodale - 04-17-2021, 09:00 PM
There are currently 7648 online users. [Complete List]
» 2 Member(s) | 7646 Guest(s)
