Threads: 44
City: Menlo Park
State, Province, Country: CA
A bit of veneer work. I wiped a little stain over the repaired section, just to see how it would blend in. Since the rounded section hasn't been cleaned up, it makes it appear still to be lifting - it isnt. I think this will be quite respectable when the rest of the top is cleaned up and toned appropriately.
And here is a little work performed to pull the delaminated parts of the grill back together. Still working on how to integrate the missing piece, perhaps support from a thin backing, but I have made something, as mentioned earlier.
RE: Zenith 6S27 - by EdHolland - 04-20-2021, 08:24 PM
Hello Tim,
Hello Tim,
Hi Dan,
Hello Tim,
bk1077bradiorich — 09:01 PM |
