Atwater Kent model 20 Big Box
Pardon me for the delay. Thanks Mike and Chas for your information. Have purchased from A.E.S. many times in the past, I'll do some research on them and the ARBE-III web site.
Well Chas, I did try my two old Triplett analog multi - meters. Both with fresh batteries and good old sharp probe ends. Pulled a 1.8k and 18k resistor from my meager supply. Selected the proper scale, zeroed each meter and each read the correct resistance for each resistor. I tried each transformer pair a half dozen times each and the needle for each meter never moved at any scale. Even cut the wires closer to the transformer just in case of a broken wire some where in the wire run. No luck. Then pulled out my digital meter with same result. One Triplett is model 60-NA other is model 630-A.
If you do find 1 or 2 transformers in your stock, your offer is indeed generous and I would like to work with you if possiable.
Thanks
Tim
Atwater Kent model 20 Big Box - by TTech - 04-18-2021, 05:49 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-18-2021, 05:53 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-18-2021, 06:56 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-18-2021, 09:56 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-19-2021, 12:51 AM
RE: Atwater Kent model 20 Big Box - by TTech - 04-19-2021, 10:14 AM
RE: Atwater Kent model 20 Big Box - by Chas - 04-19-2021, 11:46 AM
RE: Atwater Kent model 20 Big Box - by Eliot Ness - 04-19-2021, 01:31 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-19-2021, 05:59 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-19-2021, 07:47 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-19-2021, 08:52 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-20-2021, 09:47 AM
RE: Atwater Kent model 20 Big Box - by Chas - 04-20-2021, 11:28 AM
RE: Atwater Kent model 20 Big Box - by TTech - 04-20-2021, 12:15 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-20-2021, 02:29 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-21-2021, 08:19 AM
RE: Atwater Kent model 20 Big Box - by Chas - 04-21-2021, 10:54 AM
RE: Atwater Kent model 20 Big Box - by TTech - 04-21-2021, 01:01 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-21-2021, 11:13 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-22-2021, 04:45 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-22-2021, 05:30 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-23-2021, 08:18 AM
RE: Atwater Kent model 20 Big Box - by TTech - 04-23-2021, 05:28 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-24-2021, 09:39 AM
RE: Atwater Kent model 20 Big Box - by TTech - 04-24-2021, 11:03 AM
RE: Atwater Kent model 20 Big Box - by TTech - 04-25-2021, 10:52 AM
RE: Atwater Kent model 20 Big Box - by Chas - 04-25-2021, 11:20 AM
RE: Atwater Kent model 20 Big Box - by TTech - 04-25-2021, 12:51 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-25-2021, 04:59 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-26-2021, 05:18 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-29-2021, 01:38 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-29-2021, 05:23 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-29-2021, 06:01 PM
RE: Atwater Kent model 20 Big Box - by Chas - 04-29-2021, 06:10 PM
RE: Atwater Kent model 20 Big Box - by TTech - 04-29-2021, 06:41 PM
RE: Atwater Kent model 20 Big Box - by Phlogiston - 05-01-2021, 04:15 PM
RE: Atwater Kent model 20 Big Box - by TTech - 05-01-2021, 08:18 PM
RE: Atwater Kent model 20 Big Box - by TTech - 05-02-2021, 02:02 PM
RE: Atwater Kent model 20 Big Box - by Phlogiston - 05-02-2021, 05:17 PM
RE: Atwater Kent model 20 Big Box - by TTech - 05-03-2021, 02:35 PM
RE: Atwater Kent model 20 Big Box - by TTech - 05-04-2021, 03:47 PM
RE: Atwater Kent model 20 Big Box - by TTech - 05-04-2021, 06:26 PM
RE: Atwater Kent model 20 Big Box - by Chas - 05-06-2021, 12:05 PM
RE: Atwater Kent model 20 Big Box - by TTech - 05-07-2021, 09:34 AM
RE: Atwater Kent model 20 Big Box - by TTech - 05-07-2021, 09:58 AM
RE: Atwater Kent model 20 Big Box - by Chas - 05-07-2021, 10:50 AM
RE: Atwater Kent model 20 Big Box - by TTech - 05-07-2021, 12:46 PM
RE: Atwater Kent model 20 Big Box - by Chas - 05-07-2021, 01:01 PM
RE: Atwater Kent model 20 Big Box - by TTech - 05-12-2021, 09:59 AM
RE: Atwater Kent model 20 Big Box - by admin - 05-12-2021, 10:26 AM
RE: Atwater Kent model 20 Big Box - by Phlogiston - 05-12-2021, 06:18 PM
RE: Atwater Kent model 20 Big Box - by TTech - 05-12-2021, 09:49 PM
RE: Atwater Kent model 20 Big Box - by Chas - 05-14-2021, 12:13 PM
RE: Atwater Kent model 20 Big Box - by OZ4 - 05-17-2021, 12:57 PM
Eico 232 VTVM Schematic
