  • 1 Vote(s) - 4 Average
Identifying my Record Player
Hi and welcome,
>I know nothing about it (year, value, origin, anything!
I couldn't find anything on it. The model numbers that are used on the US models vs the same units out of CA are different. I did look around a bit but to no use.
Probably made around the mid '60s. Value 0 to maybe $40 US in good working order and looking like new. Origin ... Canada.
Identifying my Record Player - by BlakeW - 04-24-2021, 02:32 PM
RE: Identifying my Record Player - by Radioroslyn - 04-24-2021, 07:09 PM
RE: Identifying my Record Player - by OldRestorer - 04-25-2021, 07:15 AM
RE: Identifying my Record Player - by BlakeW - 04-25-2021, 03:22 PM
RE: Identifying my Record Player - by Phlogiston - 04-25-2021, 04:42 PM
RE: Identifying my Record Player - by BlakeW - 04-25-2021, 05:22 PM
There are currently 10251 online users. [Complete List]
» 2 Member(s) | 10249 Guest(s)
