A rare 16L variant?
I've been thinking about that, Tom. Should I attempt to save it, especially since cabinet work is not one of my strong points?
I thought about it some more as I measured the legs for Gvel this morning. 7 inches, Greg, so they are too long for a 37-675.
A rare 16L variant? - by Ron Ramirez - 04-03-2011, 08:04 PM
Re: A rare 16L variant? - by gvel - 04-03-2011, 09:00 PM
Re: A rare 16L variant? - by Ron Ramirez - 04-03-2011, 10:23 PM
Re: A rare 16L variant? - by ekimetsok - 04-04-2011, 09:26 AM
Re: A rare 16L variant? - by TA Forbes - 04-05-2011, 11:10 PM
Re: A rare 16L variant? - by Ron Ramirez - 04-06-2011, 12:33 AM
Re: A rare 16L variant? - by gvel - 04-06-2011, 06:15 PM
Re: A rare 16L variant? - by Steve Davis - 04-06-2011, 10:16 PM
Re: A rare 16L variant? - by TA Forbes - 04-06-2011, 11:11 PM
Re: A rare 16L variant? - by Ron Ramirez - 04-06-2011, 11:17 PM
Re: A rare 16L variant? - by Arran - 04-08-2011, 08:26 PM
Philco 91 Tuning Condenser
There are currently 10177 online users. [Complete List]
» 2 Member(s) | 10175 Guest(s)
