Dial Scale Removal
I've a model 610, just 610 that's going to need the dial scale replaced. I know there are repros out and that's great, but how do you remove those scales off of their mountings? Can someone direct me to an illustration or just let me know how it's done on this forum?
This set was mentioned earlier on in the forum. Wow, what a player. Just jumpered in a few 10mfd's to get rid of the LOUD HUM to hear if it's going to be a player or not. Sounds real good. Back to the soldering tool to do it right. Thanks all for your help.
GB
73 de,
Gary/N9VU
Dial Scale Removal - by n9vu - 04-03-2006, 10:34 PM
Dial removal - by AI2V - 04-04-2006, 01:12 PM
Re: Dial removal - by n9vu - 04-04-2006, 09:23 PM
