Early Philco impregnated wire
The regular wire, if you do not see the mesh or a drain wire soldered to the braid (which is easily discerned even under the cloth, and that wire is much fatter) is not shielded.
Early Philco impregnated wire - by radio1 - 04-30-2021, 06:28 PM
RE: Early Philco impregnated wire - by morzh - 04-30-2021, 09:30 PM
RE: Early Philco impregnated wire - by OZ4 - 04-30-2021, 10:49 PM
RE: Early Philco impregnated wire - by morzh - 04-30-2021, 11:31 PM
There are currently 8558 online users. [Complete List]
» 1 Member(s) | 8557 Guest(s)
