philco 60 -505
Yes, you will find it listed there under Model 60.
http://www.nostalgiaair.org/Resources/793/M0013793.htm
Don't forget, Model 60 underwent numerous changes during its nearly three year production run. All of the changes are documented here:
http://www.philcoradio.com/tech/60evol.htm
philco 60 -505 - by denver - 04-06-2011, 06:53 PM
Re: philco 60 -505 - by Ron Ramirez - 04-06-2011, 07:03 PM
Re: philco 60 -505 - by denver - 04-06-2011, 07:05 PM
Re: philco 60 -505 - by 7estatdef - 04-07-2011, 06:37 PM
Re: philco 60 -505 - by denver - 04-08-2011, 09:46 AM
The speaker table error?
Philco 70 antenna lead
