Permanent Magnet as a Philco Replacement Speaker?
I recently acquired a Philco model 38-5 tombstone that is missing the speaker. I have placed requests in the "Wanted" sections of various radio sites but have come up empty. As a temporary solution I would like to install a permanent magnet speaker until I someday find an original. While I've restored a quite a few radios in my time I have never had to replace an electrodynamic speaker with a permanent magnet type and am unsure how to proceed.
I'm missing:
- the output transformer
- the field coil
(are the output transformer and the field coil the same thing?)
- the voice coil
I've done some searching and it sounds like using a choke of the appropriate rating is preferred to using a resistor and bumping up the capacity of the filters when replacing the field coil so I'd like to go that route.
In the absence of the original speaker how can I determine what the voice coil resistance is?
I'm not even sure how to begin Icon_redface. Any advice would be appreciated.
Geoff
Permanent Magnet as a Philco Replacement Speaker? - by Guest - 04-04-2006, 04:11 PM
[No subject] - by Chuck Schwark - 04-04-2006, 10:26 PM
[No subject] - by Guest - 04-05-2006, 12:06 PM
[No subject] - by Chuck Schwark - 04-05-2006, 12:48 PM
