RCA 56X5
Hello Mike,
what great Set and I really look those older RCA radios too I am finishing up a Bendix from about the same time period for a customer this weekend and it also had one those firecracker capacitors and I too am going to do the same The terminal strips work great .
RCA 56X5 - by mikethedruid - 05-19-2021, 10:34 PM
RE: RCA 56X5 - by Paul Philco322 - 05-20-2021, 07:26 AM
RE: RCA 56X5 - by radiorich - 05-20-2021, 09:18 PM
RE: RCA 56X5 - by mikethedruid - 05-20-2021, 09:23 PM
RE: RCA 56X5 - by mikethedruid - 05-20-2021, 11:15 PM
RE: RCA 56X5 - by mikethedruid - 06-01-2021, 04:40 AM
RE: RCA 56X5 - by mikethedruid - 07-19-2021, 10:41 PM
RE: RCA 56X5 - by EdHolland - 07-20-2021, 01:30 PM
RE: RCA 56X5 - by Paul Philco322 - 07-20-2021, 08:43 PM
RE: RCA 56X5 - by mikethedruid - 07-20-2021, 10:01 PM
Eico 232 VTVM Schematic
There are currently 9021 online users. [Complete List]
» 1 Member(s) | 9020 Guest(s)
