Miller I3-PC1 Capacitors
You can browse thru the Miller catalog  https://worldradiohistory.com/Archive-Ca...log-59.pdf  but I doubt it's going to disclose that information. The general consensus is about 100 mmfd. The proper value is determined by trial and error.
Miller I3-PC1 Capacitors - by Daniel Bingamon - 05-22-2021, 04:17 PM
RE: Miller I3-PC1 Capacitors - by Radioroslyn - 05-22-2021, 05:44 PM
RE: Miller I3-PC1 Capacitors - by Chas - 05-22-2021, 07:14 PM
RE: Miller I3-PC1 Capacitors - by Daniel Bingamon - 05-22-2021, 08:35 PM
RE: Miller I3-PC1 Capacitors - by Chas - 05-22-2021, 09:25 PM
RE: Miller I3-PC1 Capacitors - by Daniel Bingamon - 05-23-2021, 08:34 AM
RE: Miller I3-PC1 Capacitors - by Daniel Bingamon - 06-02-2021, 08:38 PM
There are currently 4538 online users. [Complete List]
» 1 Member(s) | 4537 Guest(s)
