Philco 201X incognito
Big order from Sal came in so to thought I get started on the 201. Cursory look told in was pretty good but I was a little troubled by # 98. It's a 70H 10ma choke that supplies the B+ up to the mixer section. Connected right after it is a 4mfd cap.
Looked kinda burnt and didn't smell so hot either. Check online and found this:  https://www.aliexpress.com/item/4000879432503.html Philco used high inductance low current chokes. Ron was looking for one years ago for a 600 series set.
A little dusty.     Gotta get some oms after that dial      Got #102 out and cut it open. It was a C/D replacement so no tabs on the bottom. Replaced the innards with a pair or 22mf in series yielding 11mfd @ 900v. Just did it to raise the ripple current rating. The answer to the next question is I'm impatient and lazy. Hopefully in the next day or so I can get the 8 electrolytic caps rebuilt.
Here's #101 it's the tricky one. Blue terminal goes to the + of the 8mfd cap, the silver terminal connects to the junction of the - of the 8mfd cap and the + of the 10mfd @ 50v. The - of the 10mfd @ 50v connects to the tab/shell or to the ct of the hv winding.
Philco 201X incognito - by Radioroslyn - 05-28-2021, 04:05 PM
RE: Philco 201X incognito - by Radioroslyn - 05-29-2021, 04:40 PM
RE: Philco 201X incognito - by RodB - 05-30-2021, 09:33 AM
RE: Philco 201X incognito - by bgorman - 06-02-2021, 12:24 AM
RE: Philco 201X incognito - by Radioroslyn - 06-02-2021, 10:11 AM
RE: Philco 201X incognito - by Ron Ramirez - 06-02-2021, 03:20 PM
RE: Philco 201X incognito - by mikethedruid - 06-02-2021, 05:38 PM
RE: Philco 201X incognito - by Ron Ramirez - 06-02-2021, 09:29 PM
RE: Philco 201X incognito - by bgorman - 06-02-2021, 09:48 PM
RE: Philco 201X incognito - by Radioroslyn - 06-03-2021, 02:59 PM
RE: Philco 201X incognito - by Radioroslyn - 06-03-2021, 06:54 PM
RE: Philco 201X incognito - by Nathan Slingerland - 06-04-2021, 09:20 AM
RE: Philco 201X incognito - by Radioroslyn - 06-08-2021, 04:00 PM
RE: Philco 201X incognito - by Radioroslyn - 04-02-2022, 06:21 PM
RE: Philco 201X incognito - by bgorman - 08-12-2022, 06:37 PM
RE: Philco 201X incognito - by Radioroslyn - 08-15-2022, 05:29 PM
I did run into a guy on the FB Philco Radio Enthusiast page who is searching for the output transformer for a 46-480, so...jrblasde — 10:12 PM
I may have just found the IF transformer. There is a person on FB Marketplace who is selling a 46-480 in need of some re...jrblasde — 10:10 PM
Restoring Philco 96
Have just bought this. The field coil tested at 3.18K. The cone has one small tear. I think this is what I need. Not ...morzh — 06:22 PM
91H Code 126 Restore
Well I am making progress with my first Philco.  It took a bit to figure out the on/off/band switch and tone control nei...RealRider — 01:33 PM
Interesting design in that the plate circuits of the first detector and IF stage take full B+ right from the filament of...462ron — 08:44 AM
Hello mike, that is lucky that you were able to do that ! I have one of my radios that the volume control is getting s...radiorich — 12:18 AM
That one cannot be taken apart well. It is riveted. But the domed switch luckily has some spacing (not much and not inte...morzh — 09:44 PM
Hello Mike, that D5 is great for switches and I do the same I will try spraying it through a side hole first before tak...radiorich — 09:38 PM
Almost decided ot turn it on, but didn't like the power switch being 50 - 100 Ohms, so it is the same exact switch as in...morzh — 08:56 PM
Philco 49-1040
+1 Bob. Yeah, they bought it in 1949 or so, but by 1960, with the CRT starting to dim and after having the set repaired...MrFixr55 — 04:41 PM
