Dial Plate Restoration with Kinko's
Radio Daze used to sell a glass reproduction of one of these, I bought one a few years ago. One problem with printers is they can't reproduce the gold pint these dials, or white unless you print it on something white. Someone of the other forum found someone that could reproduce glass dials, it was a company that did commercial lettering for car windows and it was not the cheap vinyl peal and stick junk either.
Best Regards
Re: Dial Plate Restoration with Kinko's - by Arran - 04-10-2011, 02:22 AM
