Philco 42-380 Plastic front bezel
Hi Fred,
Renovated Radios caries the bezel/escutcheon. You will need to re-install the brass strip from your old bezel into the new one.
Really no need to recreate the vast majority of Philco knobs; most are plentiful.
https://renovatedradios.com/
RE: Philco 42-380 Plastic front bezel - by Brad Winder - 06-06-2021, 11:18 AM
