Found my old vom
Once you get it up and running you should get it to agree with readings from the old service literature. One of us has to answer at least one post a week on the subject. Who's turn is it?
Got one myself, and restored it a long time ago, afraid to look inside as the bateries have surely leaked again
Found my old vom - by 7estatdef - 04-11-2011, 06:47 PM
Re: Found my old vom - by codefox1 - 04-11-2011, 06:52 PM
Re: Found my old vom - by 7estatdef - 04-11-2011, 07:07 PM
The speaker table error?
Philco 70 antenna lead
