telefunken opus 6 rectifier
Measure the current draw between the positive terminal on the bridge and the place it connects into the radio. Multiply the voltage (25) by the current you get in amps (ex. 50mA = 0.05A), this would give you a result indicating a 500 ohm resistor rated at at least 3 watts (actually 1.25W, but always go up a bit for safety and longevity.)
Your calculations will vary of course, since 50mA was just an example in this case.
telefunken opus 6 rectifier - by Jimradio - 06-01-2021, 08:23 PM
RE: telefunken opus 6 rectifier - by mikethedruid - 06-01-2021, 09:38 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-01-2021, 11:20 PM
RE: telefunken opus 6 rectifier - by mikethedruid - 06-01-2021, 11:36 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-02-2021, 01:19 AM
RE: telefunken opus 6 rectifier - by mikethedruid - 06-02-2021, 05:33 AM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-02-2021, 05:41 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-02-2021, 07:08 AM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-02-2021, 08:03 AM
RE: telefunken opus 6 rectifier - by RodB - 06-02-2021, 09:11 AM
RE: telefunken opus 6 rectifier - by morzh - 06-02-2021, 11:07 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-02-2021, 01:56 PM
RE: telefunken opus 6 rectifier - by Jimradio - 06-21-2021, 04:49 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-21-2021, 05:32 PM
RE: telefunken opus 6 rectifier - by morzh - 06-21-2021, 09:35 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-22-2021, 12:06 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-22-2021, 07:05 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-25-2021, 06:42 AM
RE: telefunken opus 6 rectifier - by Jimradio - 07-02-2021, 07:22 AM
RE: telefunken opus 6 rectifier - by morzh - 07-02-2021, 11:04 AM
Philco 91 Tuning Condenser
There are currently 10106 online users. [Complete List]
» 2 Member(s) | 10104 Guest(s)
