telefunken opus 6 rectifier
Hi,
I added a 110 ohm 10 watt resister to the bridge rectifier, it brought the voltage to what the schematic shows.
It plays wonderful, except for a little static which can be heard with radio on and without any button in the on position and with any button in the on position it is constant. It is very slight can only be heard when you are very close to the radio, the volume control has no effect on the static. Also cannot be heard when on a station, drowned out.
I am going to clean the tube pins first.
Jim
Spring Lake MI
telefunken opus 6 rectifier - by Jimradio - 06-01-2021, 08:23 PM
RE: telefunken opus 6 rectifier - by mikethedruid - 06-01-2021, 09:38 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-01-2021, 11:20 PM
RE: telefunken opus 6 rectifier - by mikethedruid - 06-01-2021, 11:36 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-02-2021, 01:19 AM
RE: telefunken opus 6 rectifier - by mikethedruid - 06-02-2021, 05:33 AM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-02-2021, 05:41 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-02-2021, 07:08 AM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-02-2021, 08:03 AM
RE: telefunken opus 6 rectifier - by RodB - 06-02-2021, 09:11 AM
RE: telefunken opus 6 rectifier - by morzh - 06-02-2021, 11:07 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-02-2021, 01:56 PM
RE: telefunken opus 6 rectifier - by Jimradio - 06-21-2021, 04:49 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-21-2021, 05:32 PM
RE: telefunken opus 6 rectifier - by morzh - 06-21-2021, 09:35 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-22-2021, 12:06 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-22-2021, 07:05 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-25-2021, 06:42 AM
RE: telefunken opus 6 rectifier - by Jimradio - 07-02-2021, 07:22 AM
RE: telefunken opus 6 rectifier - by morzh - 07-02-2021, 11:04 AM
Eico 232 VTVM Schematic
There are currently 10387 online users. [Complete List]
» 1 Member(s) | 10386 Guest(s)
