41-608 with BOL changer
Gary, good find on the BOL light. All the times I took a computer service call to find a light source askew from the sensor. You might try rectifying the 6.3 v into a 27 ohm resistor then 4 1N4002 diodes in series. Each diode has about .7 volts drop, should give you 2.8 - 3 volts constant. Oh, you'll probably need an electrolytic before the resistor, maybe 100 mfd 16 volts.
41-608 with BOL changer - by Forrest - 03-11-2021, 01:20 PM
RE: 41-608 with BOL changer - by DarrenWGaransi - 04-06-2021, 06:55 AM
RE: 41-608 with BOL changer - by gary rabbitt - 04-11-2021, 11:52 PM
RE: 41-608 with BOL changer - by Forrest - 04-13-2021, 10:05 AM
RE: 41-608 with BOL changer - by GHMueller - 04-21-2021, 10:11 PM
RE: 41-608 with BOL changer - by klondike98 - 04-21-2021, 11:14 PM
RE: 41-608 with BOL changer - by GHMueller - 04-22-2021, 08:02 AM
RE: 41-608 with BOL changer - by GHMueller - 05-04-2021, 05:42 PM
RE: 41-608 with BOL changer - by GHMueller - 05-10-2021, 05:26 PM
RE: 41-608 with BOL changer - by Forrest - 05-10-2021, 08:28 PM
RE: 41-608 with BOL changer - by GHMueller - 05-10-2021, 09:18 PM
RE: 41-608 with BOL changer - by GHMueller - 05-10-2021, 09:30 PM
RE: 41-608 with BOL changer - by Forrest - 05-11-2021, 07:05 AM
RE: 41-608 with BOL changer - by GHMueller - 06-26-2021, 06:44 PM
RE: 41-608 with BOL changer - by GHMueller - 06-26-2021, 08:48 PM
RE: 41-608 with BOL changer - by RodB - 06-26-2021, 10:04 PM
RE: 41-608 with BOL changer - by GHMueller - 06-26-2021, 11:04 PM
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
Philco 49-1040
