Stuck on non-receiving Silvertone 4769
Try injecting a modulated IF signal to the antenna. If you hear the tone then the 6J5 oscillator is not running. If you don't hear a tone then put the signal at the second IF control grid and work forward. The IF is your friend. Icon_biggrin
RE: Stuck on non-receiving Silvertone 4769 - by RodB - 06-27-2021, 09:23 AM
There are currently 9437 online users. [Complete List]
» 1 Member(s) | 9436 Guest(s)
