telefunken opus 6 rectifier
I was surprised by flimsy wires used in German radios. And super dense mounting relying on the parts rigidity to not touch things.....I had two instances of smoking due to them touching things. They bend easily.
telefunken opus 6 rectifier - by Jimradio - 06-01-2021, 08:23 PM
RE: telefunken opus 6 rectifier - by mikethedruid - 06-01-2021, 09:38 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-01-2021, 11:20 PM
RE: telefunken opus 6 rectifier - by mikethedruid - 06-01-2021, 11:36 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-02-2021, 01:19 AM
RE: telefunken opus 6 rectifier - by mikethedruid - 06-02-2021, 05:33 AM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-02-2021, 05:41 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-02-2021, 07:08 AM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-02-2021, 08:03 AM
RE: telefunken opus 6 rectifier - by RodB - 06-02-2021, 09:11 AM
RE: telefunken opus 6 rectifier - by morzh - 06-02-2021, 11:07 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-02-2021, 01:56 PM
RE: telefunken opus 6 rectifier - by Jimradio - 06-21-2021, 04:49 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-21-2021, 05:32 PM
RE: telefunken opus 6 rectifier - by morzh - 06-21-2021, 09:35 PM
RE: telefunken opus 6 rectifier - by BrendaAnnD - 06-22-2021, 12:06 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-22-2021, 07:05 AM
RE: telefunken opus 6 rectifier - by Jimradio - 06-25-2021, 06:42 AM
RE: telefunken opus 6 rectifier - by Jimradio - 07-02-2021, 07:22 AM
RE: telefunken opus 6 rectifier - by morzh - 07-02-2021, 11:04 AM
