Mystery Transitone, no photo in library!
The set appears to be one of the one (or very short run) off sets of the era. It resembles several others in the dial/knob configurations, but the cabinet is different. Also odd is the fact it is using tubes like 47 and 59, which were largely out of use by 1939, indeed most sets in the 1938 model year were using octals.
RE: Mystery Transitone, no photo in library! - by BrendaAnnD - 07-09-2021, 08:16 PM
There are currently 5531 online users. [Complete List]
» 2 Member(s) | 5529 Guest(s)
