Power supply resistors in Model 48-300
Thanks for the response exray. I don't want to plug the set in until I have the capacitors changed out. This model radio is a portable unit with a 117Z3 rectifier and 3V4 output. The other tubes are a 1R5, 1T4, and 1U5 with low filament voltages. The two part resistor is all in one long narrow unit affixed to the side of the chassis - not the typical looking resistor.
Bob
Power supply resistors in Model 48-300 - by rck46 - 04-12-2011, 07:34 PM
Re: Power supply resistors in Model 48-300 - by rck46 - 04-12-2011, 09:29 PM
The speaker table error?
Philco 70 antenna lead
