  • 1 Vote(s) - 5 Average
16B Cathedral Cabinet Restoration
[Image: https://live.staticflickr.com/65535/5131...a5f8_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
I completely disassembled the cabinet.
[Image: https://live.staticflickr.com/65535/5131...a67c_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The easy first. Re-gluing the delaminated bottom.
On to the front panel. It probably be easier the make a new front but, I want to use as much of the original cabinet as possible so, I'm going to try to repair and re-veneer this one.
[Image: https://live.staticflickr.com/65535/5131...9af7_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5131...4afd_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
I have re-glued the delamination, replaced some missing veneer and plugged the extra hole. The panel has been sanded smooth. Now, I will add another layer of veneer.
 [Image: https://live.staticflickr.com/65535/5131...e8e8_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The veneer that I have selected for the front panel.
[Image: https://live.staticflickr.com/65535/5131...7744_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5131...39a1_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
[Image: https://live.staticflickr.com/65535/5131...3de4_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
 First the edges are trimmed, the two pieces are pulled tight together with small pieces of tape, this is called "stitching", then the joint is taped long ways.
[Image: https://live.staticflickr.com/65535/5131...0d7a_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The veneer is folded and creased and a very small bead of glue is added along the edge.
[Image: https://live.staticflickr.com/65535/5131...39fa_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The veneer is flattened out and a sharp wood chisel is used to "squeegee" the excess glue. Use quite a bit of pressure and there will be no glue residue left on the surface to spoil the finish later on.
 [Image: https://live.staticflickr.com/65535/5131...9cf6_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
After the glue dries and the tape has been removed we have a piece of "book matched" veneer large enough to cover the front panel.
[Image: https://live.staticflickr.com/65535/5131...2c87_c.jpg]Philco 16B Cabinet Restoration by Steve Davis, on Flickr
The veneer has been glued and clamped.
M R Radios   C M Tubes
RE: 16B Cathedral Cabinet Restoration - by Steve Davis - 07-16-2021, 12:33 PM
RE: 16B Cathedral Cabinet Restoration - by GarySP - 07-16-2021, 03:06 PM
RE: 16B Cathedral Cabinet Restoration - by morzh - 09-05-2021, 07:04 PM
Eico 232 VTVM Schematic
Var resistor id
Var resistor id
There are currently 7823 online users. [Complete List]
» 2 Member(s) | 7821 Guest(s)
