Philco 37-60 or 38-89B?
It's a late version 37-60B -
https://philcoradio.com/gallery2/1937b/#Model_37-60B
- although it oddly uses the larger escutcheon of the 1938 version (38-60B). The reason could be that this is a transition model, one of the last 1937 models to come off the assembly line, or else Philco switched to the larger escutcheon during production of the second version 37-60B (more likely).
Philco did not always document changes, which causes head scratching, arguments, etc. among collectors these days.
Philco 37-60 or 38-89B? - by Jordanbkc - 07-18-2021, 05:00 PM
RE: Philco 37-60 or 38-89B? - by Ron Ramirez - 07-18-2021, 05:47 PM
RE: Philco 37-60 or 38-89B? - by Jordanbkc - 07-18-2021, 06:02 PM
RE: Philco 37-60 or 38-89B? - by Ron Ramirez - 07-18-2021, 08:16 PM
Philco 91 Tuning Condenser
There are currently 9304 online users. [Complete List]
» 1 Member(s) | 9303 Guest(s)
