Power supply resistors in Model 48-300
Codefox1: Thanks for the response. I'm sure you are correct about R100B being open. I will check it out tomorrow. The replacement did not look like any resistor that I am familiar with. I will follow your suggestions to replace with 2 10 watt 1000 ohm resistors. Bob
Power supply resistors in Model 48-300 - by rck46 - 04-12-2011, 07:34 PM
Re: Power supply resistors in Model 48-300 - by rck46 - 04-14-2011, 09:11 PM
The speaker table error?
Philco 70 antenna lead
