Repair of on/off switch for 42-321
Does it click when you turn it?
Repair of on/off switch for 42-321 - by rck46 - 04-14-2011, 11:19 PM
Re: Repair of on/off switch for 42-321 - by 7estatdef - 04-15-2011, 07:54 AM
Re: Repair of on/off switch for 42-321 - by rck46 - 04-15-2011, 09:44 AM
The speaker table error?
Philco 70 antenna lead
