Good way to fix this blemish?
That's almost a job for "tinted lacquer" sprayed from an airbrush in very thin layers, blending edges by lightly overlapping as you fill to the centre.
Good way to fix this blemish? - by Bigreddog42 - 07-25-2021, 10:54 AM
RE: Good way to fix this blemish? - by John Bartley - 07-25-2021, 02:05 PM
RE: Good way to fix this blemish? - by Phlogiston - 07-25-2021, 06:24 PM
