Repair of on/off switch for 42-321
Yes, it has a good solid click when turned on and off.
Bob
Repair of on/off switch for 42-321 - by rck46 - 04-14-2011, 11:19 PM
Re: Repair of on/off switch for 42-321 - by rck46 - 04-15-2011, 09:44 AM
The speaker table error?
Philco 70 antenna lead
