  • 1 Vote(s) - 5 Average
16B Cathedral Cabinet Restoration
[Image: https://live.staticflickr.com/65535/5133...0ce2_c.jpg]
Trimmed outer edge of veneer and sanded edge of arch.
[Image: https://live.staticflickr.com/65535/5133...7731_c.jpg]
I have attached the front arch to the base and test fitting front panel.
M R Radios   C M Tubes
RE: 16B Cathedral Cabinet Restoration - by GarySP - 07-16-2021, 03:06 PM
RE: 16B Cathedral Cabinet Restoration - by Steve Davis - 07-26-2021, 02:37 PM
RE: 16B Cathedral Cabinet Restoration - by morzh - 09-05-2021, 07:04 PM
