sx-42 hallicrafters
If you don't get anywhere using the SAMS you might want to try deciphering the RIDERS instructions. The schematic is trash but maybe between Riders and SAMS you can get somewhere.
http://www.nostalgiaair.org/resources/919/M0008919.htm
You could probably use your scope in place of the output meter.
sx-42 hallicrafters - by falcon123 - 08-04-2021, 07:36 AM
RE: sx-42 hallicrafters - by RodB - 08-04-2021, 09:52 AM
RE: sx-42 hallicrafters - by mikethedruid - 08-04-2021, 01:03 PM
RE: sx-42 hallicrafters - by mikethedruid - 08-04-2021, 01:12 PM
RE: sx-42 hallicrafters - by falcon123 - 08-04-2021, 08:55 PM
RE: sx-42 hallicrafters - by mikethedruid - 08-04-2021, 09:27 PM
Eico 232 VTVM Schematic
There are currently 6481 online users. [Complete List]
» 2 Member(s) | 6479 Guest(s)
