sx-42 hallicrafters
I just looked through the files from that BAMA site. There are several versions of the schematic, all pretty clear, some better than others. I suggest you pick your favorite, the one you find is clearest, download it onto a thumb drive, take it to an office supply place which does large scale printing, and have them print you up a large copy of the schematic. You will also find the original Hallicrafters service bulletin and instruction book for the model on that page. Good luck ! should be a great receiver when you're done.
sx-42 hallicrafters - by falcon123 - 08-04-2021, 07:36 AM
RE: sx-42 hallicrafters - by RodB - 08-04-2021, 09:52 AM
RE: sx-42 hallicrafters - by mikethedruid - 08-04-2021, 01:03 PM
RE: sx-42 hallicrafters - by mikethedruid - 08-04-2021, 01:12 PM
RE: sx-42 hallicrafters - by falcon123 - 08-04-2021, 08:55 PM
RE: sx-42 hallicrafters - by mikethedruid - 08-04-2021, 09:27 PM
Eico 232 VTVM Schematic
There are currently 6478 online users. [Complete List]
» 2 Member(s) | 6476 Guest(s)
